Which Clutch Pedal Assy. Year?!?
GrandeStang73
93
VA
I have a 1973 Mustang, and converting it from automatic to manual. I am putting in a 1993 T-5 5-Speed. Which pedal style do I need for cable clutch. A clutch pedal from a 93' or equivalent or a 73' set-up?? Thanks for any feedback! :SNSign:
Buy a clutch cable kit (as far as I know it will work on it) from Mustang Steve. Get a 73 clutch pedal and put it in your stock bracket (after you weld quadrant from cable kit on),trim the brake pedal down. and you are good to go.
Make sure you can just bolt in the clutch pedal to your existing assembly. I did the exact same conversion and my pedal assembly didn't have the bushings for the clutch pedal.
But you will definitely need a pedal assembly from a '71-'73 Mustang. If you get another complete assembly make sure that it matches the same braking system that you have in the car. In other words, if you have power brakes make sure you get a power brake clutch pedal assembly and if you have manual brakes get a manual brake assembly.
