Yes I went through the checklist I found after a search here. Here's what I got:
Ford 5.0HO engine with the full ford motorsport setup for swap into a jeep. Harness, mass air, sensors, etc. Been running fine for a few years, then the alternators started blowing diodes (GM 1 wire types). I just upgraded to a PA performance 3G. I'm running a lincoln MKVII fan which pulls 40+ amps- I thought that was blowing the alternators. 3G Worked great for a month. Then the battery died again. I roll started it by popping the clutch and got home. Now it won't start at all.
Engine cranks fine after a new starter (was turning slow and tested bad).
Battery is good (pep boys machine test)
I have power to the coil- but no spark out of it
Fuel pump runs and 38psi on the rail
Noid light on the harness indicates no signal to fire injectors
12 volts present at red wire on injector plug
changed to a new distributor, ignition module, cap, rotor, plugs, MSD coil
I just checked every power wire for the harness using the ford motorsport manual. Every 12v, ignition on, cranking only, and crank/run is the right power. I checked the grounds (ECU, harness x2)- good to go.
ECU relay has power
With ignition on- check engine light comes like normal and the fuel pump runs for a few seconds.
I give up- could the ECU be fried? What the heck is keeping the coil from firing and the injectors from pulsing? Any way to check the ECU? Anything I'm not thinking of?
ECU relay has power
