Wilwood, Front brakes, 12,19"..
LW_horse
37
Sweden
Wilwood, Front brakes:
Has someone tried to modify the 12,19" rotor kits below to fit a Mustang 65-67 or 70 spindle?
Early ford, 1937-48, #140-8583
Pinto / Bobcat, 1971-80, #140-7017
Mustang II, 1974-78, # 140-7017
Wilwoods own kits for early Mustangs has only 11,75" rotors, which is a "poor" match to their 12,19" rear disc brake kits (with parking brake).
I am pretty sure you can, I can find out for sure tomorrow for you. I have Cobra Automotive's "Big spindle" which I pretty sure is the large bearing 70 spindle. I also Have the wilwood SL6 Big Brake Front hub kit for a 1971-1980 Pinto 1974-1978 Mustang II Part No: 140-7018-B. Ill give CA a call and find out what spindle it is for sure, I can't rember off the top of my head. So I would figure you could do the same just with the different kit.
I have to keep digging, around i know i have better pictures of the whole setup.
LW,
I'm a little confused by your question. Do you want to modify the Wilwood 12.19"
rear brake kit to fit on the front spindle?
If so, I would think that would be more trouble then it is worth.
If your just looking for a 13" Front brake set up to complement the Wilwood 12.19" rears,
then Global West makes a nice kit that fits '70 large pin spindles -
http://www.globalwest.net/mustang_1964 -73 catalog.htm#Pro-Vintage Disc Brake Kits
Tim
do they make a kit that is about 13" for the front of a 69? all i see are smaller kits and i dont know what one to pick..
Info below from Wilwood catalog & Summit Racing..
Wilwood front brake kit, 13" rotors:
MAKE: Mustang
YEAR: 1968-69
OE SPINDLE TYPE: Disc/Drum
NOTES: Kit includes hub assembly
WITH GT ROTOR: #140-9501 (Summit => $1,418.95, ships end march..)
WITH SRP ROTOR (slotted & Cross-drilled): #140-9501-D
HOSE KIT: #220-9195
MAKE: Mustang
YEAR: 1968-69
HOSE KIT: #220-9195
That Wilwood kit from Summit will change your wheel offset - 1/2" outboard.
Tim
LW,
Tim
Hi Tim;
I want to use the #140-7143 rear kit with 12.19" rotors in rear, and a matching front kit with 12.19" rotors.
I do not want to go with bigger rotors, since I'm running both street & strip 15" tires (0 and 6mm offset).
Regards;
/Lars
Lars,
I don't think you are going to get those 12.19" rotors inside a set of 15" wheels.
You are going to need to stick with 11.75" rotors for 15" wheels.
Check out the HotRodsUSA site - http://hotrodsusa.com/ - it is very informative
and has some well put together kits.
Tim
Thanks for the link & tip Tim.
Seems like I need to have a thorough look 15" rims fitment with 12,19" front rotors.
However, Summits homepage says min. wheel size is 15"..
Regards;
/Lars
I've had a look at Cobra Automotive's homepage, and their "Big spindle" appears to be the 70-73 drum spindle, which is close to my 70 disc spindles.
68FBJJZ109; What kind of modifications did you perform? Modification of the caliper bracket? New bracket? etc
Need your help here.
Regards;
/Lars
What size is that rotor and what size is the wheel?
