i just repainted my engine bay, im looking to get rid of most of the vaccume lines that arnt really nessary if anyone has a diagram or any info it would be much apreciated .thanks
What do you have removed that would allow you to dump vac lines? Do you have AC or heater? Do you still have your EGR?
If you have your EGR removed, then you can remove the EVP and the two sensors below it and get rid of those vac lines. If you don't have AC or heat, then you can pretty much get rid of the canister and main vac line running from the intake over to the canister.
I still have AC, but plan on removing it. But when I do, I will still want the heat to work for defrost and the blower motor so I will need to control the evap doors. So I still have the vac line from the canister to the evap case. But I have my EGR removed, so I removed the EGR, EVP, and the two lower sensors and all the vac lines. So now I just have the one vac line coming from the intake to the canister, and the line going from the canister to the AC evap case.
Besides those, you will still obviously still need the vac line going to the fuel regulator.
