trav_19
Of course you can use it on your automatic ABS or no-ABS. Here's how it will go for you:
-Stop the car and keep it in Drive or 1st.
-Now you gotta PUMP the break pedal til it is very hard to push in. Its ready. So KEEP it pushed in.
-Flick your switch(on/off switch) or use the switch they give you with your kit which you need to hold it ON for it to work.
-Release your brake pedal and still hold the switch ON.
-At this point, you dont have any brakes in the rear, only the front will hold you in place.
-Do your burnout in 1st I guess. Depending of your gearing/rpm you might need to shift the tranny to 2nd gear.(maybe 3rd for all I know)
-When there's enough smokeand your tires are sticky release your button/switch that you're still holding and the stang will start to move forward.
Enjoy.![]()
well that seems simple enough at the burnout box...i would use my own toggle in the ashtray switches since i have a opening available
but how does staging work?? when i roll up to the line if i loc the front and preload im just going to start another huge burnout right?? is line loc not usefull at the tree for a auto car??
That car was awesome!
