couple H/C/I ?'s
ShortThrow50
923
Pa
93 5.0- doing trick flow top end
190 pump 0r 255 with 24 pound injectors? Will have fuel pressure regulator
High volume oil pump or stock? is it necessary? Will not consider swapping to larger pan.
Windage tray? yes or no?
Upgraded ignition coil with stock distributor? Is it worth it?
upgrade alternator? Id rather not if i dont have to.
thanks
oh and yes I will be doing everything else for the setup such as maf, tb, etc, etc
also heres a link to the progress so far with pics
http://forums.stangnet.com/showthread.php?t=695554
thanks
255 will be good. u cant go too big on the fuel pump. the engine only gets what it needs. be sure to get a correctly cailbrated MAF so your car knows it running a bigger injector
Standard volume. with a stock pan u run the risk of sucking the oil pan dry at high RPM
windage tray will help power a bit, reduce drag. if u want to, get one.
coil wont matter the plugs only get the spark needed to run.
if u want better charging get one. if u have UD pullies u may want to grab one.
good luck
I would go with the 255 pump. and 24lb injectors
I have a high volume pump. I like it but you really need a 7 quart pan with one.
Windage tray is a good idea. They free up HP that friction is robbing from you.
Your stock ignition system will work fine. The only reason I would upgrade is if you plan on running juice and you want the timing retard functions of an aftermarket unit.
I would upgrade the alt esspecially if you have a large stereo in the car or you want to run UD pullies or an electric fan.
Get a standard pump...it will flow plenty for you with h/c/i.
The larger fuel pump take more amps...190-255lph will be fine. I run a 190lph.
I suggest 24lb injectors. I run 30's and they are not needed.
I wouldn't run a windage tray since your sort of on a budget anyways (with the alt. comment). Not worth much to me for a daily driver/street car.
With the h/c/i upgrade you don't need an alternator upgrade, but sometimes it just a good idea in general - aftermarket stereo, guages, e-fan, etc...it helps your lights not dim at idle. It just depends if your car 'needs' it or not...depends on your setup.
Good Luck!
