93 5.0- doing trick flow top end
190 pump 0r 255 with 24 pound injectors? Will have fuel pressure regulator
High volume oil pump or stock? is it necessary? Will not consider swapping to larger pan.
Windage tray? yes or no?
Upgraded ignition coil with stock distributor? Is it worth it?
upgrade alternator? Id rather not if i dont have to.
thanks
oh and yes I will be doing everything else for the setup such as maf, tb, etc, etc
also heres a link to the progress so far with pics
http://forums.stangnet.com/showthread.php?t=695554
thanks
