95opal - Sounds good, that intake is pretty versatile - gear it for what you want. You want all out straight speed, go with the gear that matches your combo, not someone elses. Our cars specs are all different - power, weight, tire height, tranny gearing, and more importantly on how you drive it, etc. As for throttle body, a 65,70,75mm will all flow the same cfm your engine can use. The larger mm, the touchier the gas with same performance. Just take a check on Accufab's website, they got all the info there to back it up. When you swap it over, post up, I'd like to hear your results!
