well got the engine out and torn down slightly. (due to making a heck of a knocking sound)
so anyway when I removed the oil pan I found a few things... lots of metal shavings (which I didn't find when I drained the oil while the motor was in the car btw), and about half of a washer looking thing. what is there is also a little cracked. whatever it is is in bad shape and most likely cause the problem.
took apart some of the head (the valve train from the cylinder that got the bad compression before) and there is nothing there that even resembles this piece I found in the oil pan. closest thing to it is the outer edge of the valve spring retainer, but it doesn't match up perfect. I sat a retainer next to the chunk I found in the oil pan to give you an idea in the picture.
anyone know what this could be?
now the other question is, do I scrap this motor and just find another one or keep going? I really wasn't planning on pulling the crankshaft and rebuilding everything is going to cost more than just buying a new motor. I really though the problem would be in the heads but they look fine so far.
