Are you suggesting that a street car with .510" lift hydraulic cam needs 7/16 studs? A stud girdle too? Or maybe a Jesel set up? They are the strongest.
It was my understanding that the Energizers were the same rockers that came on the last 5.0 Cobras from the factory. I haven't used them yet, but the ones I bought even have the ford part number cast into them.
You are correct. Crane simply carried on with them as their Energizer line after the Ford contract was done.
Plus you'd have a choice of off the shelf pistons instead of customs.How are you going to do the 400 rods? Aren't the big ends bigger than the journals on the 302 crank? Seems to me, just using a set of lower end (costwise) aftermarket 5.4" rods would be the way to go for that.Plus you'd have a choice of off the shelf pistons instead of customs.
So you're basically going to have the rod/stroke ratio the 351M had, but without the heavy assed pistons.
Maybe do a Clevor using a set of Aussie Cleveland heads? Now that would be a one-off motor.Ah! I thought you were going to do a 302 for some reason.![]()
Everytime I wake up on the road after a 6-8 hour nap, there's a nice stream of oil and water leading away from it. (the water's from the A/C condensation)I thought the whole long rod theory had been debunked essentially.
And me, being a 30 year veteran of driving 18 wheelers, never gave it a thought as to why they all have(well probablby 99%) inline engines. The Kenworth I drive now will roll over it's millionth mile next Monday. And it's only been overhauled once.But it being a Detroit Diesel, upholds its reputation as an oil leaker.
"D", how in the world are you able to do that much driving and monitor Stagnet and put up over 7000 posts? You got one of them direct satellite up links and throw up tech while you are shifting gears?
HistoricMustang
www.historicmustang.com
Have used Harland Sharp for years with no issues at the track. Pay a few extra bucks!
http://store.summitracing.com/egnse...4294889096+4294839887+115+300684&autoview=sku
HistoricMustang
