Procharger 05-07
I actually called procharger and the kits would work from 05 to an 07. The rep said that I would have extra peices that I wouldn't need for the 07, but that is niether here nor there cause this ballbag sold the kit just now to someone else. Oh well:nonono:
The 07s have different cooling setups. There is only 1 upper radiator hose on the 07s, and it's split into 2 on the 05-06s. Most supercharger kits require modifing the upper radiator hose to fit. That's the difference.
Poop is correct, and I know it doesn't matter since someone nabbed the thing out from under you. I have an 05-06 stage 2 intercooled kit on my 07. All that was required to make the kit work is weld shut one of the openings on the puke tank (as poop mentioned they eliminated one line in 07), and tap the lower line to route over to the remaining tank opening. Everything else is exactly the same across the rest of the years.
