Kenne Bell or Vortech
ga94gt
138
Ringgold GA
I am in the market for a supercharger and it haas come down to the KB or the Vortech. I got off the phone with Anderson ford and the guy that tunes their cars said the KB realy makes a LOT of heat which kinda scares me. The reason I like the KB is because it is simple to put on and just takes a few hours.
But i have never heard anything bad about Vortech. I have always heard they make a good product.
I am just looking for some help on which on would be the best choice for my car.
Any thing would be helpful.
Thanks Garrett
Depends on what you want, if you want a ton of low-end torque go with the kenne bell, its a good piece, if you want more mid-high end power go with the vortech.
Yes the KB does put out alot of heat, alot of guys go methanol injection with it which also adds like 60 hp and cools the charge down. or you can intercool it.
But with forced induction the tune is where the life of your motor comes from, even if it does put out alot of heat if you have a good safe tune you'll have no problems.
+1
you have a 5.0.. You DON'T need a kenne bell.. You will never be able to hook it up without slicks and serious mods.. The vortech helps where the 5.0 is weakest....Top end.. Mine kicks in a little above three and pulls hard to redline.. The vortech is even simpler to install than the kenne bell minus punching a whole in the oil pan..
But, if you want the best of both worlds...... Go turbo... I am..
With good heads and the right cam and intake, the top end on a 5.0 is not a problem either.
FYI, A 2.2L kenne-bell will pull hard all the way through the red line.
If it is a street car, the KB will be more fun and feel faster stoplight to stoplight. At the track, a Vortech MIGHT get you lower times.
I love my vortech. With my setup, the power really comes on at 3400-4000 so I have decent traction starting off so I'm not just sitting in one place spinning my tires. Only problem....if I downshift to 2nd or 3rd I have to be careful. Reliability wise the vortech has given me no problem at all...And also, with the meth injection kit I can run crazy timing/more boost. It was very easy to install, too.
that said....
If I had the dough I'd put a 2.2 KB on there and outfit it with a meth injection kit.
Everybody has their idea of what is best
but
When it comes to traction and not being able to hook.
I don't know a Stang out there with just a little bit more power than
stock that can hook all that well in first gear :Word:
The belief that more low end torque is somehow or the other :scratch:
undesirable ... is just something I can't embrace.
I want that torque for the other 4 gears I have that follow first gear ;)
When driving around town in a street car ........... Really ..........
How much time do you spend in first gear.
My little mild NA combo will easily spin the tires in first or second
but still
I'd gladly take more low and mid range torque :banana:
I'm not putting down Centri Blowers :nono:
but
They have their applications
and
The KB's have theirs as well
Grady
Good thoughts Grady. One thing to look at would be how you're gonna build your car as well. Will it be a top-end car or a bottom-end street driven car.
Me, I love top-end power which is why I went with the vortech. Making more top-end I can run a steeper gear ratio and take advantage of gearing. Of course...that's a trade-off with comfort as you'll be shifting more often.
Don't get me wrong, I love low-mid power too.....which is why I chose the parts I did.
Everyone has their preferences...the best thing I can say is......get a plan together for your car, research, research...and research some more.....and then buy. Otherwise you'll never be satisfied and will end up spending tons of money upgrading/changing things around
but
but still
but
and
Grady
Why don't you just swap in a Diesel Grady? :D
The car will be a street car and maybe see the track 1 or 2 times a year.
As for my plans later I want to do a 306 with some AFR 165 and a nice little cam and a few more things to get it to the ground.
I was leaning to the KB because of its low end tourq and the instant boost they make.
Get the Kenne Bell. In fact, I will bet money that with a properly tuned 2.2 Kenne Bell you'll not only run faster on the street, but faster at the track as well, running the same boost as the Vortech.
Average power is what moves a car down the track, peak power is what moves a car out of the dealership lot. 3.73s might not be the right gear for that blower though. You'd have to experiment yourself.
Don at LaSota racing has run some sick fast KB setups, see if you can shoot him a PM. Very helpful guy.
Adam
I like my vortech but if I were to do it all over again I would probably try out the KB. The only thing I dont like about the Vortech is that I have to rev it all the way up to get any power out of it. It is still a fun little car though...
Jon
Thanks for your participation in this discussion :nice:
I'd like to ask you a Q or two about your experiences with your Vortech :D
How much total boost do you see
If you are in a higher gear like 3rd ......
at low rpm like say 1500 and go WOT .....
Please describe the experience as the rpm's climb
Like at what rpm do you JUST start to feel the benefits of boost
Maybe something like at what rpm do you see
25% of your boost
50%
75%
100%
Just looking for a more specific description of how the Vortech makes
its power ... other than ... it comes on at higher rpm's
Grady
I wish I had a way to get my dyno graph onto the computer. My peak boost is 11 psi. The boost really starts comming in at around 3000. at 4000 its at 5 psi, at 4500 its at 7.5, and 5000 its at 9. Peak is just under 6k. Peak HP is made just under 5500 RPM, peak torque is at 4000.
I'm happy with my decision on the Vortech. I never drove a KB car so I have no basis for comparison nor will I try to compare. I can just say I'm not disappointed with my S trim. I can blow the tires away in first and second gear and 3rd if I'm not careful!! I'm seeing 15psi on the high side so it makes the car all that much funner.
Another thing with the Vortech is, if you hear/feel signs of trouble, you have a chance to get out of it before instant and certain damage accurs, with a KB, full boost comes swiftly so once you know you're getting into trouble, it's too late. I see alot of blown HG threads associated with KB's and Turbos.
if you can send me the numbers, i can make a graph in excel and post it.
or post the numbers here and grady will probably beat me to it :cheers:
let me know
I have had both, it just depends what you want. They both are great! It's one of the must have's once you drive them!
One thing I wanted to say about the Vortech when you are not making boost. As soon as you floor it the bypass valve closes so ALL the air from the blower is going into the engine......even though your gauge is not showing boost it still feel's stronger than N/A since the engine is not having to "suck" the air in.
