horn stopped working
U2SLO450
118
well my horn crapped out the other day and i have no idea on how to fix this. Do i just buy a new horn or is there someway to test it out or something? I need to get this fixed because inspection time is coming up:notnice: (the funny thing is thats all the guy does is pull my car in and blow the horn, nothing else:D )
Run 12 volts directly to the horn(s) to see if anything happens. If nothing, then head to Autozone or wherever and get some super-duper-loud OEM horn replacements for like $35 a pair, and scare the crap out of your inspector. :D
Also, check to see if you're getting 12 volts to the horns - might require a second person, if you have to sit there and hold the multimeter leads onto the terminals to see if it's getting any juice. If not, then it could be a relay, fuse, and/or switch problem.
Easy fix, like he said first check it to make sure its getting power, and if it is getting power and doesn't work just go buy a replacement for find a junkyard. Just pop out the inner fender and unhook/bolt it and away yah go.
which fuse is it for the horn/cruise?
#16
Thanks to TMoss!!! Source site: http://www.veryuseful.com/mustang/tech/engine/
My first mustang was an 87 lx hatch. I had a problem with my horn where it would work and not work off and on. I found out when I took off the horn button that it wasn't the horn itself but, the horn button. The copper ring under the button was corroded. I brush it a bit and used a approved electric cleaner and it work for a bit and then stopped. I then replaced the whole wheel just because the padding was bad and had no problems after that.
The horn circuit has a button that supplies ground, a relay that uses the button to switch the horns on and off, and two horns. The relay reduces the current that the horn button has to carry. This makes it possible to use a small and simple switch and slip ring on the steering wheel.
attachment.php
The horns typically develop an internal short to ground, which causes the fuses to blow. :eek:
The horns are located under the car on the driver's side, forward of the front wheel well. Disconnect BOTH horns, replace the fuse: if the fuse blows immediately, the problem is most likely in the cigar lighter circuit. If not, then press the horn button on the steering wheel: if the fuse blows the problem is in the wiring between the horn relay and the horn. If doesn't blow when you press the horn button, connect ONE of the horns and try again. If it still doesn't blow the fuse, connect the other horn. Chances are that the first horn you re-connect will blow the fuse. Whatever horn blows the fuse at this point has an internal short and is trash. Time for a trip to the junkyard... :crazy:
I should also mention that I once left my top down and it started raining and the power mirror switch got wet. It caught fire the next morning and blew the fuse. I unplugged the switch and replaced the fuse and everything worked. Now I still need a damn switch.
