OK, but will the fox a-arms work with the sn95 spindles on a fox?
The SN95 A Arms are too long and the Ball joint is wrong for Fox Spindles.
The ball joints will work..
yes they will. I have a set of 96 spindles I will be installing on m 82 Capri. Some say that 96 and up spindles will push your front track too much for standard backspacing on Mustang wheels others say it wont. Some say 94-95 spindles, I guess its up to you I do know that if you go with PBR calpiers you will need to grind on the 94-95 spindles and with 96 and up its a direct fit.
Have fun.
In Post #3 it says would Fox Spindles work on SN95 A Arms, I dont think you would ever get the Castle Nut on. Not sure why anyone would want SN95 Arms and then use Fox Spindles on them either.
The fox ball joint is longer and you need to use a spacer with it..
The Ford Racing M-3075-A A Arms are a great Bargin as they have new bushings and upgraded Balljoints.
Anyone know a good place to get these a-arms?
Allen
