A arms question..
They say all FOX Stangs and Capris are the same (Fox 79-93) however I have heard that 90-93 are different because of some extra guard welded on due to the switch over to 16" wheels, its kinda like the Fender opening is bigger on 90-93 Stangs for the same reason. I think SN 95s stangs are longer so it would widen your track and I also think they are not compatable with FOX spindles. COuld be wrong but that is what i heard.
OK, but will the fox a-arms work with the sn95 spindles on a fox?
yes they will. I have a set of 96 spindles I will be installing on m 82 Capri. Some say that 96 and up spindles will push your front track too much for standard backspacing on Mustang wheels others say it wont. Some say 94-95 spindles, I guess its up to you I do know that if you go with PBR calpiers you will need to grind on the 94-95 spindles and with 96 and up its a direct fit.
Have fun.
Have fun.
94-95 Spindles are about 5mm Wider per side than Stock and the 96-04s are about 8mm Wider than the 94-95s. Cobra, Mach1, and Bullitt Calipers bolt right up with no grinding.
The fox ball joint is longer and you need to use a spacer with it..
I am 100% Aware of this as I have SN95 Brakes on my Car and I used the Spacer. Again, go back and look at Post #3 and #6 as it asks about using SN95 A Arms with Fox Spindles, in that Oddball combination the SN95 Ball Joints would be too short to mate up with Fox Spindles!!!
