Will a 96+ IAC work?
moneypit94
1,723
Macomb, IL
I did a fox throttle body conversion and i thought i bought a 90 style iac. I think its a 96+ because it has a different end that comes straight back instead of an angle and the end itself is wrong. It bolted up perfectly.
I ordered the newer style pigtail connector for it.. Will it work or should i buy the right IAC?
Watch out if you have to do anything with the pigtail that requires cutting and splicing wires. The wires are only supposed to connect one way.
If the pigtail just plugs on your existing wiring harness you should be OK.
The pig tail is going to have to be spliced on.. Is there a way to safely determine which of the two wires goes to which side?
The solid color red wire is power and the white/lt blue wire is computer controlled ground. The IAC/IAB needs to be the kind that has the cylinder on it like the one in the picture.
The other type IAB/IAC doesn't pull air throught the MAF, so low speed air/fuel mixture ratio may be off to the lean side.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
