I figured out my issues this week and need to replace my MAF. I want to do an upgrade while I'm at it, i was thinking about a 90mm Granatelli Mass Airflow and Accell 24 or 30 Lbs injectors. any ideas as to what you guys have tried and liked. Here are a list of my mods so you can tell me what you think i should go with.GT40 upper and lower
Trick Flow Stage 2 Cam
Roller Rockers (These were installed before I got the car so i dont know the ratio but they are blue if that helps)
Under Drive Pulleys
Tremac Trans
383 Gear.
I tried to use the diagnostic plug but its dead (this was a 4cyl car that someone did a v8 conv) the only thing it will read is fuel pressure. When you try to get the reader to give you the codes it tells you it can’t read the cylinders. PLEASE HELP IF YOU GOT ANY IDEAS. I have replaced the fuel filter and ck the fuel pressure both hot a cold it was between 30 and 34psi. I also had the ign module ck and it was fine, replaced the coil to.
