1/8th mile times
Tires, you need tires. Either MT street drags, or get a set of slicks. I personally think running at the track on street tires is a waste of time. You wouldn't run a sprint wearing flip-flops....you shouldn't run at the track with street tires. :)
a set of tires makes all the difference. i remember the first time i made a pass with sticky tire i about crapped my pants. its a different feeling deal when you dump the clutch at 4k + and the car dead hooks instead of spinning.
i knew the tires would help out a lot but the sway bar thing doesnt make that much or a differnce. cuz i took it off loast time i went and this time it wasnt any different. but im only launching at about 2800 rpms to keep from spinning right off the line. it will hook decently when i do that but theres still some spinning. and the sreaon i am running street tires is becuase this is also my DD. i jus like to play at the track on fri nights
IIRC the factory shocks are around 50/50 so that wont help too much. what will help is a set of 90/10s in the front, will let the front end come up and more weight transfered to the rear of the car.
hey guys i was jus wondering if you could help me out on lowering my 1/8th mile times. you can look in my sig for my mods. but my best 60ft is a 2.03. im running street tires at 18psi. i cant get it to hook for nothin. but any help is appreciated. thanks.
You really shouldn't run any less than 20psi on street tires. The tires can cup and make traction worse. When I owned my 86 I actually got the best results at 24psi, driving around the water box and slipping the clutch. I was able to consistently pull 1.9 60 foot times.
