- May 26, 2004
- 162
- 0
- 0
Ok, i want to replace my stock front brakes back to stock and i need to replace the hoses. So i remove the 2 front calipers by taking the 15mm bolt on. Some said I need vice grips to remove the bolts?? Will a lot of brake fluid come out when i disconnect line? How do i stop the fluid from coming out? So everything is back together and stock brakes on then i need to bleed front brakes. So i have someone press pedal 4-5 times and then i open the valve and the pedal goes to floor while keeping pressure. Then i wait until all fluid comes out? How do i see air bubbles where am i looking? Then i tighten screw and pedal goes back to normal. Can things get messed up if bleeding brakes imporperly? Where is the bleeder screw on the front brakes? What size mm do you need?
