The problem is that my engine seems to foul plugs and I am running out of ideas. I have a 950 Holley HP and I think it might be too big for my application. With a new set of plugs the engine runs great, but within 1/2 an hour it begins to lose performance and chug. I was running Motorcraft ASF 32c plugs and when I pulled them the base ring is covered with dry, black soot. The electrode strap looked clean but gave no indication as to whether the combustion was running hot or cold, though I suspect cold. I decided to move to a hotter plug, Motorcraft ASF 42C's, and I got the same results. I dropped the jets from 73 in the front to 71 and now I just changed them to 68, but no difference - the plugs get sooty and fouled and the performance suffers.
The weird thing is that a couple of the spark plugs - cylinders 3 and 6 - are wet and covered with a black gas smelling substance. My thought is that the carb is just too big and that I should switch down to a 750 Holley.
You can see my engine combo in the sig below. I am running 15 degrees advance with and MSD 6AL.
Any advice would be greatly appreciated
