PELASE HELP FAST!!what comes with a kb??
In addition to the supercharger (which includes the supercharger, inlet manifold,discharge manifold, supercharger shaft, housing and pulley) here's the list.
Fuel system booster
11/32" x 16" Line (to PVC)
11/32" x 11" Line and coupler(to vacuum tree)
Vacuum line assembly
New drive belt (same size as stock)
Front Supercharger support bracket, idler & hardware
Manifold bolts
Lower intake manifold gasket
EGR plate gasket
TB gasket & bolts
Fuel sysytem Booster lines (2) and Safety clips
Thermostat Housing, Gasket and bolts
Radiator Hose sleeve, clamps (2) & loom clamp
Coil bracket
Coil wire
T-handle wrench
That pretty well sums it up. Be aware that if you have a GT40 intake the standard KB will not fit. Since you have 24 lb injectors you may not need the Fuel system booster (it's designed to work with the stock 19 lb injectors. At WOT the booster shuts off the return line flow which increases fuel flow to the injectors). Confirm with KB.
:nice:
Fuel system booster
Manifold bolts
EGR plate gasket
TB gasket & bolts
Coil bracket
Coil wire
T-handle wrench
Thanks man! :nice:
Is this the one? Item 300145204578. I'm wondering why it has been opened. You might want to again check with KB as new gaskets may be required.
Ya u got it, that's the one, but i dont think I will be biding on it because it is not complete, and u got me thinking about it being opened up, Who knows what, or who was in there....Thanks again for your response
Like you I was watching a couple of KB auctions before I purchased mine from KB. At the time they ultimately sold for about $400 less than new which to me didn't make sense considering you didn't know what else you might need, what the additional costs could add up to and have an older unit with no warranty.
