Belt sizing- no strings!
thaduke2003
35
Alright- here's where I'm at- I removed my P/S and smog, and my A/C is coming out- what belt size should I run, and how should I route it? I don't have string, so please give a real size- I'm stuck in the boonies bumming rides until this gets done, so please help! Will I need anything beyond a new belt? Thanks, Mark W.
stock pullies??
You are going to need to reverse your tensioner to run the belt with no a/c p/s or smog. If you don't have the means to do that, leave the a/c on as an idler pulley til you can get somewhere where you can do it right.
Kinda give yea an idea but the ac is on the belt in this diagram.
Removing accessories while out in the boonies without string is a bad idea. I gotta say that anything on the forum is nice but I'd want to check it myself since it's not often that the same exact belt works for everyone (it seems like there is +/- 0.5" tolerances on the short belt swaps.
Do you floss? Go fishing?
Good luck.
How could I swap the tensioner around?
And yes, I know it's not the smartest, but it wasn't quite planned- my p/s pump's return line nipple snapped off, and there aren't any junkyards open this weekend, AND (it gets better!) I have to be back in PA (200 miles or so) tonight- lucky me, no? :) Cheers- Mark W.
So wait... you're in the boonies where they don't have any string but they have the internet?
Do these boonies have an Advance or Autozone? Those lines are pretty common at those types of places. I'd imagine that if you expected to purchase a belt somewhere that they might also have the power steering lines.
Tear out the phone line to your computer and use it to measure the belt routing. :D
I'm sorry we're giving your crap about this. It's just kinda funny because 30 seconds with some string and you'd be set. The best I'd be able to do is measure with whatever (cut your pants up and use them :D ) and then get a couple belts either side of that measurement. One of them should fit.
also note that sometimes a belt size advertised as being one size smaller than the next will actually be larger. this has happened to me at napa and it took several days ordering belts not in stock to finnaly arive at the correct length. we had to get belts of higher or lower quality/price to get the correct fit. i am running without air pump or a/c and a power steering relocation from frpp, power pullies and march alternator brackets with out a factory tensioner since the march kit is adjustable for altertator location.
this combo uses a napa 406-0642
Alright- I found that a 725k6 works for no smog or p/s and the a/c in the factory location (unhooked, no condenser, bomb, etc.). It took 2 bummed rides to Autozone (40 minutes away is the closest, driving fast on backroads- I love living in the boonies :)) and ELEVEN different belts and pulley combos (with, without a/c, smog, routings, etc.) to figure this biotch out.
Anywho, thanks all for help and ball-busting- no offense taken, no worries- yes, the nearest traffic light is 16 minutes away (no, not 15 :)), and yes, there are hitching posts outside the next town over's general store. People in my town ARE outnumbered by: horses, cows, geese, mice, rats, blue herons (supposed to be uncommon at best), and IMMENSELY outnumbered by deer- the Mustang got her first kill last weekend, so she's helping.
BUT it's home, sweet home, with a new coolant and p/s fluid stain on the gravel driveway :) Cheers all, and wish me luck on my way back to PA for tech school- yee haw! ;) Mark W.
Does anyone know where I can find the correct belt size I need for my 86 mustang. I have a 347 Stroker engine and I used the 85 lincoln brackets for the belt setup. I'm only running the harmonic balancer, the water pump, and the alternator ( which is now on the driver's side top). Please email me and let me know if anyone has ran this setup and know the correct belt size thanks. On this set up the tensioner is set by moving the alternator
