well...tried it again
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
i tried it again..this time to light em up a little bit...but i ran into a few problems..
1...there were alot of cars coming down my street...
2: with the brake peddle to the floow it wouldnt hold the car there...just jumped foward...im going to bleed the brakes because the peddle feels a little sponge to me...
well here's the vid anyway...
make fun of it as you please...at least im trying :rlaugh:
http://youtube.com/user/svtlightning218
Well I'll cut ye a break and give ya my thoughts. From the looks of it you aren't giving your car a chance to even load up a little. Your'e just mashing the brake and stomping on the gas which isn't the best way to do it. You don't have to stomp the gas pedal to the floor to do a burnout. I know the stock stall isn't much on these cars but its enough to get it done. I give my car 70-80 percent brake I guess you could say and ease into the gas. You'll feel the rearend load up and nothing happening then ya ease into it a lil more and the tires will slowly start spinning once ya feelem break loose u can then you can gradually start laying into it more and more.
makes sence.......
that may be my problem...i was just doing half break into half thorttle... then break to the floor...it just seems to squat and shot to the left....
Keep tryin you'll get it eventually but when you figure out how to do it try to keep it at a minumum. Tires= money and plus its just added wear and tear on your car.
ill do it later on in a few months...i found a nice little place out in plain city with no cops and plenty of room to play with it at...thats what junkyard wheels are for..:D
plus i wont be keeping these to long..over the winter im gonna see if i can gather parts for an sn95 5 lug swap...this way i can run bullets...
after seeing this LX vert on em...i know thats what i want...so before the rear would get swaped im sending these tires to the tire gods in the sky...
Ummm starting at 12 sec when you were backing up you turned too much and went off the asphalt/black top or w/e, that was weaving.
no its called i was getting to where i wanted to be...middle of the right lane...i pulled out..cars turned of dexter ( about 12 houses from me..the 2 you see drive by) i backed up...turned and then straightened out....
why dont all you stop being so over critically over what i do and my car and go work on yours.
bleach just makes it easier for the tires to spin as it is a slick surface
and besides you said to make fun of it so we are. You really do make it too easy on yourself when you open a thread that way
put a vise grip on your back break line......can you say secret to 3 trophys for burn out contest at local dragstrip in a v-6 explorer? lol also bleach DOES work .....buddys and i confibulated a window washer fluid line to spray on rear tires .....smokes like crazy .....easy burnout contest win!
