Hey everybody.
I've got a '66 coupe that just doesn't want to start and it's driving me crazy.
I think I have considered most of the obvious things, so I'm looking for a little help from anyone out there with an answer to any of my questions. Here's the scoop:
Car basics:
* 1966 coupe,
* rebuilt 302 (or so previous owner says and I have not yet verified. The intake manifold code says 298, but I digress)
* Carter Performance Series (9000) carburetor
The details right now:
* 80 degrees. Southern California. 6:00 pm.
* Engine cranks, but will not start. No firing.
* I am getting a spark from coil to dist and from dist to plugs.
* Fuel pump seems to be working fine (I tested with catch bottle).
* I Propped open choke and sprayed starter fluid in carb - no help.
Recent History:
I've been driving it almost every day for five years. Always been running well up to a few months ago. Around that time I discovered there had been a leak in my radiator which really did a number on my air filter/carburetor. They were covered in crud. So...I installed a new radiator and got a new air filter.
However, I noticed that the car would stall when I started it cold and then put the car in gear. I checked out the electric choke and realized it was way off setting. I don't ever remember touching it before. Maybe it was always like that since I got it? Anyway, I reset the choke so that it would actually be CLOSED when the engine was cold. This seemed to fix my problem. I may have even over did it a little since now the engine was really revving in idle. I fiddled with the idle screws a bit. Things were fine for a few weeks until one morning my car just wouldn't start at all for the first time ever! Engine would crank and crank, but not start? Took the bus to work. Tried a number of things, but no luck. Finally, I decided to rebuild the carburetor since it was pretty darn dirty due to to the leaky radiator grime and I don't know the last time it was cleaned. Rebuilt the carb (even got a great book on carter/edelbrock carbs). Clean as a whistle now and I put it back on the car. Oh, and I got a new set of plugs and a battery, too. When I turned the key, it started right up.
Oh boy!...but...
It's been a few weeks since I've done this work and there have been a handful of times that the car still won't start.
The car DOES start sometimes. When it does, it starts up quick and strong. I've been tearing my hair out trying to find out what's going on here. Since I've owned it, I've never had a problem starting the engine. Now when I jump in the car, I don't know if it's gonna start.
Two mornings ago, I could not start the car, I propped open the choke and used starting fluid. The engine cranked and cylinders fired, but it would not totally start. I had to keep the starter motor going as it sputtered and eventually the engine started to run steady after about 16 seconds of holding the ignition switch on. It worked for the rest of the day and started up just fine later that day.
I've been leaning towards the idea that my fuel mixture is too rich and my engine is getting flooded. But would this really happen after the car has been sitting for a whole day and I just crank my engine? I tightened the idle screws to test and it seemed to have no effect.
If anybody has any clue to what might be going on here, please let me know. If you can think of any more test I can try, that would be good, too.
Thanks to anybody to took the time to read all of this and/or replied. I will updated this thread so maybe it will help somebody else in the future in the archive.
-Todd
Car basics:
* 1966 coupe,
Recent History:
The car DOES start sometimes. When it does, it starts up quick and strong. I've been tearing my hair out trying to find out what's going on here. Since I've owned it, I've never had a problem starting the engine. Now when I jump in the car, I don't know if it's gonna start. Two mornings ago, I could not start the car, I propped open the choke and used starting fluid. The engine cranked and cylinders fired, but it would not totally start. I had to keep the starter motor going as it sputtered and eventually the engine started to run steady after about 16 seconds of holding the ignition switch on. It worked for the rest of the day and started up just fine later that day.
-Todd
