4cyl swap
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
ok im getting a 89 lx hatch soon, to replace my 86gt and my wrecked 7up vert, anyways, I have the engine, trans, rear, harness, computer, speedo cluster, springs, brakes and some other stuff needed
anyways, do I HAVE to swap the k member out of my 5.0 cars in to the 4banger to make it work? I already have mounts, and trans crossmember, and mount, so do I HAVE to do this? oh and will the 5.0 harness (1990) plug up in the 4 bangers place correctly, just asking because I want to do this once and thats it lol
thanks josh
You're 4 banger k member is exactly the same as the 5.0 so just pop your motormounts on and dump the V8 in. You'll need to match your engine harness to the 89, meaning the 90 will not work. The 89 is unique. Save yourself a major headache and buy an 89 engine harness to mate with the 89's dash harness etc. I'm almost done with my 91 Notch 4 to 8 swap. It's pretty easy, just don't get rid of the wrecked 90 cause you're gonna need alot of small bits and pieces. Good luck.
this is correct. and i agree, find an 89 engine harness to match your 89 dash harness. when i did my 4 cyl conversion, my 4cyl coupe was an 88 and my donor car was a 92 GT. i tried to do it without switching out the dash harness and only a few of the plugs mated up. so i pulled it back out and used the dash harness from the 92 as well. went a lot smoother that way.
this is so off topic but i dont want to start a thread about it. but what about the fuel lines from an 86 4cyl car? im going to swap in a v-8 do i have to take my 1990 coupes lines and swap them to the 86 4 cyl?
sell what? im getting rid of the vert and the gt, and going to put everything in this hatch, its extremely straight, interior isnt that bad, needs cleaned, I has a dent into the drivers fender, the paint is peeling, and it has a flat tire, and 2 spots of primer and thats all, no bondo anywhere, no rust, nothing, drives fine the air is COLD and he wants like $400 for it, so I cant go wrong, ill just sell my interior, get rid somehow of my gt, then just transplant my crap over, like my sn booster and brakes and fuel pump and lines off the gt, harness off the vert, engine trans and rear, pony's, my 3.55's subframes, blah blah, anyways, it has more potential to be nicer than my gt, because of the body work involved, I mean I could do the suspension/brakes in 1 day if I was moving, then swap out the fuel lines, then the harness, then im home free pretty much....... it will be easy.
