Pony Center Cap Removal
JustA5.0
148
Toronto, ON
Those of you with pony rims, what tools are you using to remove the caps? I have seen the aftermath of using my flathead on both the cap and inner lip. :mad:
Hopefully someone has a suggestion (or trick) that easily obtainable at the parts store, so I can stop 'nickin' up my rims!!!
I use a flathead and pull the centercap far enough to get a finger in there and use my hands to pop them off. I don't pry on the rim, and I don't ever twist the flathead. On my set of ponys that are painted black, I lay a couple layers of masking taper over the areas of concern before even trying to remove them. I'd like to hear of better ideas too.
Something to protect the surface, with a flathead screwdriver like Vinnietbird alluded too.
Examples I used are cloth, paper towels, blah, blah, or anything laying around.
Such a simple trick, now I feel stupid. At least I was going to DIY refinish the wheels in the spring anyways, so all will not be lost.
Thanks for the help stangnet'ers
I like to customize. so i took a cheap flat head screw driver and bent the tip so it'll hook behind the centercap without knicking or scratching the rim or cap.. ( black ponies) i usually lay a towel down on the ground and pull them off. and if i drop em. they land in the towel :nice:
ya some good ideas, i just painted mine a couple months ago with dupli color high performance wheel paint, 4 coats of grey, 4 coats of clear, but when i tried to pop the caps off the paint started to all crack just like a spider web, is there any way of stoping this, every time i want to take may cap off i have to repaint the center cap, geezz must be a better way.
