Fuel injector ?
lvmustanggt
721
Las Vegas
Today I change all my lower injector o-ring gasket and found 2 of them on the passenger side have problem :mad: . Look at the picture and let me know if it's ok to use as it is or I should buy new ones. Orange plastic cap is cracked in half.
they are NOT ok to run like and you can buy the "pintel caps" in a repair kit from ne1 who sells Standard Motor Products, part # is HK-9325
checkerauto got them so I order 2 set. they sell with o-ring gasket so it was $6.99 at their store, will be here thursday.
My car is whistling for more the a year now and I change everything thinking it will solve the whistling problem but didn't , now I know why is whistling. I changed all the o-ring gasket yesterday , whistle is much quiter now but still there . I think after I changed that cap my problem will go away. Wish me luck, I will let you guys know if that caps help
Thanks for all your help
accel makes fuel injectors that are not that expensive.
as far as the whistling need more more details.
is the exhaust tightened down?
After my cams got done about a year ago then whistling started. I have change alternator,iac, idler pulley , belt and belt tensionner with no luck. Right around 1800-2000 rpm I get a whistle , people have asked me if I got a supercharger on it :(
Exhaust is tight with no problem. Every time I let off gas then I hear different whistle Vs 2000 rpm whistle. When I hold or drive at 2000 rpm it whistle real loud and if I am driving around then every time I let off gas to shift I get hiss whistle like BOV. I have checked everything for vacuum leak and look too be ok cause I have sprayed carb cleaner to see if my car die down.
Only think I am thinking now is EGR Valve. I just change it tonight , I will start her tomorrow and see if that help. I have spend so much money just changing parts thinking it might be it but with no luck.
Thanks in adavance
