what parts do you have sitting waiting to go on your car
Here are a few pics of the stuff that I need to put on the car by spring...
I'm pretty sure i have all you beat... i'm building a '86 and '91 this winter :p (Engine, tranny, body, everything... both cars ha)
Hm.... i don't even know if i should make a list. Well heres a little one
TFS CNC 205 track heat heads
TFS Track heat heads
Boss 302 (347 stroker rotating assembly)
Stock block 306 stroker
Holley Systemax ported
TFS Track heat intake
1.6 rockers(2)
AFM High rev cam
TFS stage 1 cam
90mm TB
70mm TB
95mm MAF
76mm MAF
BBK CAI
Vortech Cogged pullied Ysi (22-25lbs)
Fluidyne radiator(2)
Black Magic Xtreme fan(2)
Radiator Hoses(2)
TFS Valve covers(2)
Felpro Gasket kit(2)
Canton Oil pan(2)
PA Racing Tubular K-member with tubular a-arms(2)
Maximum Motorsports Coil-overs
MM C/c plates(2)
Eibach Pro-kit
KYB AGX shocks/struts
MM Rear lca's (2)
FRPP Rear Uca's(2)
MM Panhard bar
Swarr bar
Aluminum driveshaft(2)
Tremec TKO 600
T5
5 lug conversions(2)
Saleen ground effects(2)
Hood decals
Hood scoops
Insulators
okay well thats about a quarter of the list :rolleyes:
attachment.php
CHP 347e B50/AFR185/Custom grind cam/Forged internals
KB 2.2 Flowzilla
Snow Meth injection
Aeromotive competition sumped kit
UPR Tubular front end
QA1 Coilovers
MM CC Plates
5 lug swap:
m2300k brake setup
Yukon hardened axles- fox length
04 chrome cobra wheels
Im waiting on santa (girlfriend) with a welder to redo my engine bay then I can start putting it back together.....again. This is the last time I swear!!
At one time I was thinking about selling the car with the old vortech setup on it, instead, I decided to stick to it, and just build a really fun car to drive. Drag racing is fun, but with the amount of street driving I will be doing, Id much rather have a fun toy than a full out drag car. Dont get me wrong, you will see me at the track, but you wont see a trailer!!
Modified Blower Inlet
Smaller Blower pulley
Most of the pieces necessary for a PBR 4 wheel disk brake conversion
Things needed to pull it all together still:
PBR brackets
Larger Throttle Body
That FMS E-brake adapter thingy
New wheels/Tires
Caster Camber Plates
Time and a warm place to work. :rlaugh:
wow there are some high rollers on this board! :nice: i don't have much yet, but i'm planning on getting a little more.
VHT nite shades for my tails
my old LX tails
new brake hoses
new power steering hoses
new energy suspension swaybar endlinks and bushings
maxspeed lowering springs
MAC c/c plates i've had for about 4 years
replacement quarter panel
replacement hatch
replacement bumper support
cobra rear bumper and spoiler on the way
i think thats all...by the end of spring, i should also have new shocks/struts/quads, UPR upper and lower control arms, subframe connectors, cobra skirts and stalker nose, all new black paint. i'm excited! :D
**UPDATE** UPR uppers and lowers and UPR full length subframe connectors on the way too :nice:
Got tonns of stuff I plan on putting on my car this winter. Haven't bough any of it yet mind you, but soon, the purchasing shall commence :D
I'm probably going to switch to a Megasquirt EFI system and also I'm gonna go a little off the beaten path with fox bodies and install a Ford EDIS system off a mod motor. Should allow me to run wider gaps on the plugs, and combined with the megasquirt will allow me individual control over each cylinder as far as ignition timing goes. I also have a ton of things to do that just involve fabricating or modifying things on the car. Should be another busy winter :)
not much,
hatch
sportline springs
fuel pressure reg
a/c delete
cobra bumper
pulleys
tstat
and whatever my girlfriend gets me for christmas and my bday which is today HAHA!
in need of a fuel sending unit hehe..
