Radiator leaking
glowstang93
Feb 9, 2003
853
Illinois
Noticed a small puddle under the car this morning of antifreeze. Leaking just below the drain valve. Have a radiator ordered will be here tomorrow from O'Reilly's. It is item 433556. Its a regular radiator, nothing fancy. Never had any overheating problems with the stock one, so saw no need to upgrade. Guess 14 yrs and 91,000 miles was pretty good on a stock radiator.
Any helpful hints when it comes to putting the antifreeze back in and making sure there are no air pockets, etc in the system?
I just drove about 15 minutes from work and it was leaking when I got home and even steaming some from the drain side. :(
fill it up, run it, top it up again. the coolant level will drop when you rev the engine with the cap off, so then rev it and add coolant at the same time. i found this helped get rid of air pockets. i've seen cars with stubborn air pockets, and elevating the front end with ramps or a lift seemed to speed up the process also...
You wont have to worrie about air pockets, but i just take cap off start engine fill and wait till thermostat opens then fill and cap off..Done.
not always the case. if the cavities in the engine and system aren't well designed, high points tend to trap gasses, and coolant flow doesn't seem to flush them out. i had to try and fix an overheating old hippy van one time at my old shop, and it would only take about 1/2 the coolant it should. we had to tip it to nearly a 45* angle, and then suddenly it guzzled up what it should have, and all the air came out. there must have been passages that trapped gas no matter how much fluid was flowing by.
I agree, filling up when it drops doesn't always fix the problem. An old fox I used to have took us like 45 minutes of filing when the level dropped, we ended up jacking the car up as well, done the first time. Air pockets are a PITA.
Thanks for the help guys. I ended up having my favorite auto shop do the work. Bill wasn't bad at all. $195 all together counting the new radiator and labor. Just didn't have the time or the patience to deal with another repair at this time. I do appreciate the help. :)
