the cheapest power setup
91 HATCH
Banned
May 17, 2007
262
illinois
what would be the cheapest way to make alot of power naturally aspirated on a fuel injected 302
i was thinking this might make good power
thumper ported e7te heads
tfs stage 1 or 2 cam
gt-40 intake
70mm tb & spacer
does anyone have a similar combo that has been dyno tested
Define "alot of power" because in my book that is 700rwhp. Everybody is always trying to do things cheap with nothing. You have to pay to play:nice:
Really the only way you can get good results without spending alot of money is by buying quality parts (That may be expensive) in used condition. That way you are getting a good part for cheap because its used. You don't buy new cheap parts because like the sang goes "if its cheap, its CHEAP", and expect good results or quality.
i just think i could make the same power or more as the trick flow kit for under the 2,500.00 that the kit costs
Well yeah 2500.00 bucks for the most expensive TFS top end kit. But if you piece it all together and you add up all the parts it isn't exactly "cheap."
AFR 165/185 - Around $1400.00
Intake - 380.00(Cobra)
Head gaskets - 50.00
Push Rods - 120.00
1.6 R.R - 250.00-400.00
Valve Covers - 100.00-200.00 (Optional)
Camshaft - 250.00-300.00(Unless you by a FRPP cam)
Roller timing chain - 40.00
Valve cover gaskets - 20.00
Intake gaskets - 30.00
Head studs/bolts - 39.99
This is just a rough scetch but you get the idea... Now remember this as well.... ALL OF THESE PARTS are shipped individually now... Instead of the KIT you get them in one package and probably free shipping as well. Just something to think about.
An AFR headed 306 will outpower a TFS headed 306 in box stock trim with the same cam. A 306 with AFR 165's a 264 EX. Energy and a Crap intake will damn near make 400 fwhp.
what's the rpm range on a set up like that and where does it make peak power? Is it something that can be DD'd or would that be a track only car?
I dont know much about these heads, but I saw this in the sponsor classifieds section of TM:
• This is a top end kit for 302 & 351 small block FORD engines from 1962 TO 1991...
• It consists of:
• One pair of PBM STRIKE FORCE HEADS 2.02 AND 1.600 60cc chamber and 200cc intake runners
• SET UP FOR up to .550 LIFT
• 2.02 AND 1.600 STAINLESS PBM 1 PIECE RACE SERIES STAINLESS SWIRLED AND UNDERCUT VALVES
• CHROME MOLY PBM RETAINERS AND KEEPERS
• ERSON SPRINGS 1.260 OD 110# AT 1.800 .550 LIFT
• 3/8 19000 SCREW IN STUDS AND GUIDEPLATES
• POSITIVE VALVE STEM SEALS
• ARP HEAD BOLT KIT
• ARP INTAKE BOLT KIT
• PROFESSIONAL PRODUCTS ALUMINUM TYPOOHN INTAKE MANIFOLD
• DUAL ROW PBM ADJUSTABLE TIMING SET
• SET OF PBM LIFTERS
• 5/16 CHROME MOLY PUSHRODS
• CORTECO GASKET SET
• PERFORMANCE ERSON CAM SHAFT 218/218 .460 .460 LOBE 113
• FORGED 1.6 ERSEN/PBM ALUMINUM ROLLER ROCKERS ARMS WITH NEEDLE BEARINGS WITH POLY LOCKS
• CHROME VALVE COVERS
• VERY NICE PACKAGE
• WE APPRECIATE YOUR BUSINESS
Special pricing for the holiday season!!!!
Only $1325.00
with free shipping in the continental USA.
Be worth looking into more info on the heads for that price.
I have a similar combo that you suggested. I wasn't happy with the tfs stage 1 cam, power seem to fall off around 5k rpm. I also wish that I would have just purchased an aftermarket intake. Probably lost around 20hp using the ported stock one. Anyway you should get close to 300 whp with your combo. I made 270 hp and 300 tq with mine. I was happy with the results and now running 100 shot to make it even more fun.
