I, for one, am interested in this combination--I currently have OEM Disc brakes on my '70 Retro-mod, and since I haven't sold it yet, I'm considering upgrading it a bit at a time until I eventually do get it sold.
One of the things I've wanted to do was to upgrade to the late-model Cobra brakes, but the kits availble to do this swap are only for drum brake-style spindles.
Will this spindle be able to accomodate the late-model Cobra 13" 2-piece rotor and hub? You indicated that you would be making an adapter bracket for the calipers, but it's a little unclear whether you'd also make these stock rotors fit as well . . .
If you do indeed have these designed so they would fit, then it would be a HUGE advantage for those of us wanting to upgrade to the large brakes.
Can you clarify?
Also, do you have any timeline yet as to when they'll be ready?
Thanks!
I will be designing a hub to go with that bracket/caliper/rotor combo. I can't honestly or accurately say when this project will be done. I have MANY irons in the fire.
Mine just barely clear until I really stomp on the Baers, and then I get a scrape on the right side from upper ball joint knuckle to inside of rim. Spacers don't work, and I have ground the knuckle as far as I am comfortable. 17x8", 4.75 bs, Coy's C-67 wheel, Unique Performance coilovers. yeah, a unique case, but I am sure there are other schmucks like me with a big upper knuckle and too much BS. That sentence could be taken a few ways I am sure.
But, keep in mind I don't even remotely expect that I'm like everyone (or anyone) else.
Can I steal one from SVTCobra306's sled to do the job?
