how much gains N/A with blower cam?
htxfastlife
14
i want to know how much of a gain will a n/a stang get from some blower cams?im getting some blower cams but im not goin to get a blower for a while now,maybe a year or more. any replies is appreciated! thanks
well, i put blower cams in. a real miled stage 1 blower cam too. iv havent got my blower on yet! its been like 2 yrs. anyway, i did get stage 2 ported heads at the same time.
i really dont know what gained the power. most say its the cams as heads wont do much na. i really dont know.
with just those 2 things done i gained 35rwhp/20rwtq on the dyno. :nice:
btw, that was only the peak numbers.
the good part was i picked up more power in other areas of the rpm range.
@ 5500rpm = 43rwhp/41rwtq
@5900rpm = 48rwhp/44rwtq. now some of this power i believe came from the ported heads. i think they helped the cams out in the other rpm ranges.
trick flow intake
bbk75mm tb
bbk cai
patriot heads stage 2 and blower cams
electric water pump
bbk longtubes and off road x- pipe
centerforce clutch
pro 5.0 shifter
upper control arms/umi lift bars
90mm maf/42lb injectors/fuel regulator/255lph f-pump
aluminum driveshaft
nitto dr's
i'll be getting a supercharger later on and maybe a cobra aluminum block....i havent decided on a place to get it dynoed yet, any recommendations? a good friend of mine is going to help me put everything on..(save me some money)
trick flow intake
bbk75mm tb
bbk cai
electric water pump
centerforce clutch
pro 5.0 shifter
aluminum driveshaft
nitto dr's
I always use Richard at Strictly Performance. Steve at Houston Performance is not bad either. Also, there is couple others, such as slaters up near Humble, and PSI motorsports in south houston.
