- Jan 6, 2008
- 14
- 0
- 0
i want to know how much of a gain will a n/a stang get from some blower cams?im getting some blower cams but im not goin to get a blower for a while now,maybe a year or more. any replies is appreciated! thanks
im getting cms stage 2 blower cams with patriot heads...
You'll definately notice those cams even N/A. I also just added 2 more grinds to the CMS line up. A stage 2.5 blower and a stage 2.5 N/A.
quick question. Do you need to get a tune after installing cams?
trick flow intake
bbk75mm tb
bbk cai
patriot heads stage 2 and blower cams
electric water pump
bbk longtubes and off road x- pipe
centerforce clutch
pro 5.0 shifter
upper control arms/umi lift bars
90mm maf/42lb injectors/fuel regulator/255lph f-pump
aluminum driveshaft
nitto dr's
i'll be getting a supercharger later on and maybe a cobra aluminum block....i havent decided on a place to get it dynoed yet, any recommendations? a good friend of mine is going to help me put everything on..(save me some money)
I always use Richard at Strictly Performance. Steve at Houston Performance is not bad either. Also, there is couple others, such as slaters up near Humble, and PSI motorsports in south houston.
