Did I hook my catch can up backwards???
SilverBullet00
1,150
Wichita, KS
So yesterday on the way home from work my car died 3 times on deaccel. When I got home and poped the hood I noticed that my PCV line going from the oil seperator to the intake plenum was SUCKED flat so hard it was ripping the rubber hose!
I started to think about it, and now I am wondering if I have the seperator facing the right way. Currently I have the flow coming out of the valve cover, through the seperator, and to the intake plenum. So the arrow on the seperator is pointed at the plenum.... is this correct?
If it is, maybe I just need a higher flowing unit?
I would think this is the correct direction...the flow is going toward the plenum. I'd think the problem is the separator...too restrictive.
I gotta ask why are you going back into the plenum? I thought the idea was to just plumb the PCV to a vented catch can...?
+1! I just disconnected my PCV totally....but because it's no longer hooked up to the plenum there isn't any pressure forcing oil to spray everywhere. Probably if I wanted it to be a bit cleaner I could hookup a catch can or a heaterhose pointing down to the ground, but its winter so I don't care lol :nice:
oh, come on! 25 Views and no responses? Someone has to know which way this things faces... my head hurts from thinking about it!!
We are all too distracted by your avitar to help you ;-)
Is your PCV valve good ?
Here is an alternative to replacing the broken Ford puke tank:
http://forums.stangnet.com/showthread.php?t=402405
I don't know if it will keep you emissions legal however as it might fail inspection.
I think this is what I am going to do as well... Hide in my inner fender or something...
You can see mine. Not worried about it it's no show car.
I'm using the Steeda Oil Seperator. Installed it over a year ago and have no tyet seen one drop of oil in the little glass catch jar. I guess maybe it's because my car only has 37000 miles on it? I know it's hooked up properly.
