A PDF version of this How-To is available here:
http://www.buildingeleanor.com/images/2008/pdf/Ledchange.pdf
<b>Article:</b>
<font color="black">One thing that always bugged me about our cars is
the mycolor option is only limited to the dash. Why couldn’t Ford
really go above and beyond and allow all the LED’s to be controlled by
the mycolor buttons? I had some hope when I heard of the ambient
lighting package of the 08 but this still leaves the dash buttons and
switches that pale boring green. I finally decided to change them out
myself. Apparently “Mycolor” is blue since that is what my dash has
been set to since I got it. The switches in the mustang use two types
of LEDs</font>
<ul><li><font color="black">PLCC-2</font></li><li><font color="black">Standard through-hole domed</font></li></ul><font color="black"><b>PLCC-2 SMT LED total =50 </b></font>
<font color="black">Radio: 26</font>
<font color="black">Mycolor sw: 3</font>
<font color="black">TCS: 1</font>
<font color="black">A/C: 15</font>
<font color="black">Cruise L: 2</font>
<font color="black">Cruise R: 3</font>
<font color="black"><b>Through Hole LED total =7 </b>(can use PLCC-2 style - details in soldering section)</font>
<font color="black">Window DR: 2</font>
<font color="black">Window PS: 1</font>
<font color="black">Lock Driver: 2</font>
<font color="black">Lock Passn: 2</font>
<font color="black">First thing to do is remove the switches from the
car. One of the nice things about the S197 mustang is that it is easy
to take apart.</font>
<font color="black">To do this swap you will need the following:</font>
<ul><li><font color="black">PLCC-2 LEDS of your preferred color (See above for quanity) </font></li><li><font color="black">Through-hole LEDs (I chose not to use them) </font></li><li><font color="black">Low wattage Soldering Iron (Flat or small tip preferred but not required) </font></li><li><font color="black">Solder (I use Silver Bearing solder with a
Rosin core. This stuff is awesome and I’ve been using it for almost 10
Years and haven’t found anything that works better on electronics)</font></li><li><font color="black">Small Tweezers </font></li><li><font color="black">Solder Sucker (optional) </font></li><li><font color="black">Desktop vice (optional) </font></li><li><font color="black">Patience</font></li><li><font color="black">More Patience</font></li></ul><b><font color="black">Cruise control switches:</font></b>
<font color="black">My car has the IUP steering wheel so I am unsure of the standard wheel</font>
<ol style="list-style-type: decimal;"><li><font color="black">Remove left and right IUP panels by slowly lifting them out.</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/cc_1.jpg" border="0" /></font>
</li><li><font color="black">With the panels removed, lift the outside edge
of the button assembly towards you. The harness connects on the inside
edge so take your time and be careful not to damage them. I didn’t have
to but you could always remove the airbag assembly to gain better
access to the connectors</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/cc_2.jpg" border="0" /></font>
</li><li><font color="black">Once out there is one screw on the back and a few tabs securing the button assembly together.</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/cc_3.jpg" border="0" /></font>
</li><li><font color="black">Once separated you will remove the circuit
board, rubber membrane, and contact pegs. Do this for both sides. There
are 2 LEDs on the left switch and 3 on the right</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/swcover.jpg" border="0" /></font>
</li></ol><font color="black"><b>Center Dash and Radio Removal:</b></font>
<font color="black">To remove the center dash piece you must first remove the console finish (upper) panel.</font>
<ol style="list-style-type: decimal;"><li><font color="black">Lift the Trim bezel (Auto) or Shifter boot from the console. (item1) </font></li><li><font color="black">Place the parking brake in the up position </font></li><li><font color="black">Lift the console lid and remove the 2 screws at the back of the finish panel (item 2) </font></li><li><font color="black">Lift the upper finish panel from the back and slowly work your way forward (item 3).</font>
<font color="black">Be careful and take your time, you don’t want to scratch anything </font>
</li><li><font color="black">Place the manual boot through the hole and remove the panel.</font>
<font color="black">(I removed mine completely) </font>
</li><li><font color="black">Remove the two center stack wings by grabbing at the bottom and pulling them towards you (item 4)</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/console.jpg" border="0" /></font>
</li><li><font color="black">Remove the 6 7mm screw securing the center panel </font></li><li><font color="black">Remove all electrical connections</font>
<font color="black">The AC plugs are a bit tedious to remove. The one
on the fan switch has a release tab and the one on the vent selection
has a release tab and a grey lever that must be lifted. The switches
and Accessory plug have a press release (See pic on step 11).</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/acplug.jpg" border="0" /></font>
</li><li><font color="black">Remove the 4 7mm bolts securing the stereo and disconnect the 3 plugs and antenna plug. </font></li><li><font color="black">Remove the stereo and set it aside </font></li><li><font color="black">The top buttons are removed from the panel by pressing the 4 tabs (2 top/bottom) and pushing through the face of the cover.</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/dashplug.jpg" border="0" /></font>
</li></ol><font color="black"><b>Mycolor / TC button and Radio Dissasembly</b></font><ol style="list-style-type: decimal;"><li><font color="black">On
a work surface remove the 4 back screws of the upper switches and
separate the circuit board from the front and back. Do this for both.</font>
<font color="black">(If you look real close you’ll realize the switch boards are the same but flipped over for the opposite side)</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/tc_back.jpg" border="0" /></font>
</li><li><font color="black">Stereo: Remove the 2 Torx screws on each side of the face plate</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/rad_side.jpg" border="0" /></font>
</li><li><font color="black">Remove the volume knob by pulling it away from the stereo</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/rad_3.jpg" border="0" /></font>
</li><li><font color="black">Lift the locking tabs on the top and bottom of the face plate and gently pivot the face away from the body</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/rad_4.jpg" border="0" /></font>
</li><li><font color="black">Disconnect the two plugs running from the circuit board at their connection port in the body. </font></li><li><font color="black">Remove the 4 screws securing the face to the circuit board and remove.</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/rad_front.jpg" border="0" /></font>
<font color="black"><u>If you are replacing the Green Lens plate perform steps 7-9 otherwise skip these steps</u></font>
</li><li><font color="black">Remove the white backing and black support plate.</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/rad_9.jpg" border="0" /></font>
</li><li><font color="black">Remove the CD /AM-FM buttons by lifting the hinge-points and pushing them through the front of the face plate.</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/rad_7.jpg" border="0" /></font>
</li><li><font color="black">Using a small screwdriver in the notched area lift the lens cover from the face plate (carefully).</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/rad_8.jpg" border="0" /></font>
</li></ol><font color="black"><b>AC Controls Removal / disassembly (2005 – 2006):</b></font><ol style="list-style-type: decimal;"><li><font color="black">Remove the 4 Torx screws securing the control to the dash plate.</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/ac1.jpg" border="0" /></font>
</li><li><font color="black">Remove the 3 control knobs by pulling the knobs away from the AC assembly</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/ac2.jpg" border="0" /></font>
</li><li><font color="black">Depress the 4 tabs (2 each) on the top and bottom of the control module and separate the cover</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/ac3.jpg" border="0" /></font>
</li><li><font color="black">Remove the 3 Torx screws securing the circuit board and separate</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/ac4.jpg" border="0" /></font>
</li><li><font color="black">Remove button membrane </font></li><li><font color="black">Mark the green LEDs with a marker so you remember which LEDs to remove</font>
<font color="black">(The following pic can be used as a guide)</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/ac_lit.jpg" border="0" /></font>
</li></ol><font color="black">Note: 2007 – 2008 AC controls see <b><u>method 2</u></b> of the following document:</font>
<a href="http://www.silverhorseracing.com/Install_sheets/S197-525-07%20Climate%20Control.pdf" target="_blank">http://www.silverhorseracing.com/Ins...%20Control.pdf</a>
<font color="black"><font color="black"><b>
Door Lock and Window Switches Removal disassembly</b></font></font><font color="black"><font color="black">To
remove the lock switches you have to remove the door panel. I removed
one without removing the panel and it was quite difficult. </font></font>
<font color="black"><font color="black">1. Door panel</font><font color="black">
<a href="http://www.buildingeleanor.com/images/2008/pdf/doorpanel.pdf" target="_blank">http://www.buildingeleanor.com/image.../doorpanel.pdf</a></font><font color="black">
2. </font>Window switch removal
<a href="http://www.buildingeleanor.com/images/2008/pdf/window.pdf" target="_blank">http://www.buildingeleanor.com/image...pdf/window.pdf</a><font color="black">
3. Separate switch assembly by depressing tabs on the side.</font><font color="black">(be careful the plastic is fragile - I had better luck lifting between the tabs to remove)</font><font color="black"><b><br /><br />Headlight switch (Non-Fog version)</b></font><font color="black">
<br />The headlight switch uses a standard bulb. I will update this to LED when I install my DIY ambient light kit.</font><font color="black">
1. Make sure Left stack wing is removed</font><font color="black">
2. Pull driver lower pillar cover</font><font color="black">
3. Pull the bottom of instrument panel slightly to open enough space</font><font color="black">
4. Remove 2 screws from the bottom of steering column cover plate</font><font color="black">
5. Slowly lift panel and separate</font><font color="black">
6. On the back of the switch there is a small keyed plate. Turn it counter-clockwise to unlock and pull the light out</font><font color="black">
<font color="black"><b><br /><br /><br />Removing / Installing the LEDs:</b></font><font color="black"><u>
<br />Surface Mount</u></font><font color="black">
<br />A low wattage soldering iron is preferred since you want to have as little heat as possible. (I use a 15w)<font color="black"><br />1. Prepare part by placing it on a flat surface securely<font color="black"><br />2. Make sure your iron tip is clean. I use a fine point when soldering</font><font color="black">
<br />3. Make note of factory LED orientation, there should a bevel on the corner noting the polarity of the LED.</font><font color="black">
<br />4. Apply iron to upper side of factory LED until solder flows.</font><font color="black">
<br />5. While applying heat, use the solder sucker to remove the solder and repeat for the other side.</font><font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/solder_suck.jpg" border="0" /></font>
<font color="black"><font color="black">6. If LED does not slide from circuit board, reapply heat and lift side with tweezer.</font><font color="black">7. Repeat for other side if necessary</font><font color="black">
8. If any solder remains after removal, reheat and remove with sucker</font><font color="black">9. Apply a small amount of solder to iron tip until it holds a bead on the end.</font><font color="black">
10. Using tweezers hold the new LED in the original location and orientation as the original.</font><font color="black">
11. Apply the pre loaded tip to one side of the LEDand repeat for other side</font><font color="black">
12. If more solder is needed reapply.</font><font color="black"><u>
Through Hole</u></font><font color="black">
The LEDs in the window and lock switches are through hole LEDs.</font><font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/doorsw.jpg" border="0" /></font></font>
</font></font></font></font><ol style="list-style-type: decimal;"><font color="black"><font color="black"><font color="black"><font color="black"><font color="black"><li><font color="black">Make note of the polarity of the LED</font>
<font color="#000080">(I chose to use the SMD LEDs instead of the through-hole style since I hadn't ordered them)</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/polarity.jpg" border="0" /></font>
</li><li><font color="black">Cut the original led off closest to the LED dome</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/cut_led.jpg" border="0" /></font>
</li><li><font color="black">Slightly bend the top of the terminal to make a surface to mount the LED </font></li><li><font color="black">Pre load the tip of the iron with solder. </font></li><li><font color="black">Using tweezers if necessary place the LED against the terminal and apply pre loaded solder</font>
<font color="black"><img src="http://www.buildingeleanor.com/images/2008/led_project/cut2.jpg" border="0" /></font>
</li><li><font color="black">Once complete repeat for remaining LEDs</font></li></font></font></font></font></font></ol><font color="black"><font color="black"><font color="black"><font color="black"><font color="black">Reassemble switches in reverse order and reinstall in your mustang.</font>
<font color="black"> </font>
Here's a collage of the end results
<img src="http://www.buildingeleanor.com/images/2008/led_project/collage.jpg" border="0" /><b>
A couple of notes:</b></font>
</font></font></font></font><ul><font color="black"><font color="black"><font color="black"><font color="black"><font color="black"><li>If I were to do it over
again I would probably use a lower mcd level LED. The LEDs I used are
600mcd and 200 - 300 would probably be better especially if you have
mycolor. If I didn't have mycolor I would have replaced them all and it
wouldn't have been that big of a deal</li><li>The door lock switches are difficult to remove. I actually cracked
a piece that holds one tab on one of them. This was probably due to it
being about 20 degrees outside when I did this. I would pull the door
handle assembly and heat the areas with a hair dryer or low watt heat
gun to make it easier</li><li>Take your time. I don't have the most steady of hands but I love to
solder. I usually rest my hands against something to help keep them
steady</li><li>Try to handle all circuit boards by their edges. This helps eliminate the possibility of ESD damaging the components.</li><li>The stereo LEDs are more difficult to remove due to the fact it
takes longer for the solder to flow. My soldering iron can switch from
15w - 30w and I only had to switch to 30W once or twice due to my impatience</li></font></font></font></font></font></ul>
<b>Article:</b>
of LEDs</font>
