Is this a sign of a bad computer?
New: Distributor (stator was bad), coil and TFI test as good.
The car won't start with the spout connector plugged in and using the stock ignition system but it will start without the spout plugged in.
Now, the car will start and run with the spout connected or unconnected with the MSD6al ignition system but I get some misfire when cruising in say 4th gear at 2200 rpms.
What diagnostics can be done to verify a bad computer?
If it is a bad computer, where can I get a computer other than a salvage yard?
Thanks
Update: Started the car (stock ignition) without spout connected let it idle to normal operating temperature and then checked for any codes - no codes. So I then installed the spout while the car was running and it ran with the spout connected, just won't start with the spout connected.
Thanks
