I have two different MAF's and need the curves for them. Flow vs. output voltage. I can not find anything on them. They may both be the same ... thanks.
F67F-12B579-EA
F37F-12B579-FA
F67F-12B579-EA
F37F-12B579-FA
Can you elaborate on the setup a little?I have a spec racer ford with a Rousch engine
Really, it isn't difficultHum ... this sure seems very difficult.
I don't know where I am starting from, as I have said, because the table has already been tweaked by Rousch.
The part numbers you gave above are not for a stock 5.0 HO Mustang.So ... do you by chance have the stock data for the MAF or know where I might get it? I believe this one was on a 5.0 but I am not sure. I think it was also on the Ranger 2.3 and 3.0.
There are other parameters that should be dealt with before the MAF Transfer...The new 2.0 engine does not run correctly with this ECU and MAF. However, I have made some adjustments in the ECU and the engine runs "pretty good" It is still lean in WOT under 70% + load. Without an accurate MAF transfer I really am just chasing it.
Rex
LOL … So ... like I said ... this sure is difficult. I only asked for a MAF table. I think I can conclude that it isn't available so ... I will try get this one flowed at the University Aero Lab.There are other parameters that should be dealt with before the MAF Transfer...
Engine Displacement Scalar
Injector Slopes
Load Scaling (especially with the addition of boost...)
(and I am sure there are more that I'm forgetting at the moment...)
If you have all of these parameters exposed/hacked, then you're in good shape...
If not, it may be easier to convert to another ecu....
The Ford Thunderbird had a 2.3 turbo for a couple of years, and several of those ecu's are well documented.
The Ford Taurus SHO had a v6 ecu which is also well documented.
I don't mean to discourage you from taking the time to hack out the binary for the ecu you have.
But I have tried to go that route myself, and I found it easier to deal with converting an LA3 ecu to MAF & n/a. (I'm in the middle of this project right now)
Just more options to consider,
jason
what is the computer code? i doubt i have it, but i may.
disregard, i may have the mass air transfer function for the eec.
So, Rex...
It seems that you are looking for MAF Transfer files based on the MAS part number and Housing size.
This info does not exist, as far as I am aware...
The way we find our Ford MAF Transfers right now is by looking up the stock binary for the vehicle that MAF was used on.
It would be nice to have that info, but I don't think it has been compiled this way before...
