He has a C4, not an AOD...
at 6000 rpm in 3rd, you'll be able to go 124.48mph, so if you plan on going faster than that in the quarter mile, then they are too much.
So at 3000 rpm, you'll be cruising at 62.24mph, or 3133rpm at 65. If that cruising rpm bothers you, then you need a different gear.
Hope that helps![]()
No, I am around 3200 RPM when I am doing 75-80.
Then either you don't have 3.73's, your tach or speedo are way off, or you have an overdrive transmission and don't know it![]()
It's a C4 3 speed w/manual valve body. No OD. Tach could be off, but then so would my Auto Meter tach since they read about the same.
Then you've exhausted the only other option. Your speedometer is off.
Unless your tires really are not 26 inches in diameter.
The formula doesn't lie my friend.
The speedo very well could be off. I don't have anything to test it. The tires definitely are 26" though. I wasn't saying you're wrong. You could be right, but I can only go by what I see & what info I have.![]()
