I just had the car aligned back in October and I've driven it about 1000 miles since. I dont think its out of alignment from potholes because it still drives the same, which is pretty good.
I've still got a tire wear issue on the front driver's side. I cannot figure this out! This is the 2nd tire to do this. The passenger side tire wears perfect. I do rotate the tires and they only have about 10,000 miles on them.
You can see in the photo the tread is normal except for the outside edge. The cord is showing through.
Any ideas? Here are the alignment numbers from the machine:
CASTER:
Left: 5.4 deg
Right: 5.2 deg
CAMBER:
Left: -0.4 deg
Right: -0.5 deg
TOE:
Left: .10 deg
Right: .10 deg
CASTER:
Left: 5.4 deg
Right: 5.2 deg
CAMBER:
Left: -0.4 deg
Right: -0.5 deg
TOE:
Left: .10 deg
Right: .10 deg
