you mean the center stack and the console?
For the console, Inside the storage compartment, there is the felt, under the felt, there are 2 screws. 5/16 should do it. Pull straight up, then tilt foward enough to get your hand underneight to undo the cig outlet and then you can remove the box.
now pry up on the shifter bezel, the part that attaches to the console. I have pulled mine a hundred times and haven't broke any clips. Just pull straight up and will even controlled force. It will pop off with miniamal force. There are two more screwns toward the top of the console, this will loosed up the console enough to route cableing ect.
Now the center stack, grip the bottom near the TC and defrost buttons, pull toward you with like force from before. This will pop the bezel off. Pull till you hear 4 clips pop. then grab the top of the bezel and pull staight out to pull it from the AC vents. Don't forget to unhook the three switches as the bottom of the stereo bezel if you have them.
This is just from the top of my head. I don't know what year your car is, so I dont know if this is even much help. But its pretty easy to take these cars apart. Ford didn't do alot of R&D on much of anything.
