08 GT
williebill39
08 GT oil burning?
Hi everyone,i'm new to this forum,my question is on my 08 GT there opperes to be a puff of blue smoke upon starting after setting for a few hours,the stealer says this is normal due to a rich charge of fuel upon shut down ,they claim it is not oil,my 99 GT never did this,is this unique to the 3 valve,thanks for your feed back. P.S.there is omly 650 miles on the Mustang.
Blue smoke is oil. That has nothing to do with running rich. They need to look at it more thoroughly. Make sure they've got the right oil in it and that there aren't any fouled plugs.
Many 4.6 3V engines, mine included, will put out considerable blue smoke upon startup, if the engine was run for only a short time on the previous startup. Example: Moving the car from the driveway into the garage so that the engine is started and run for only 20 seconds. Mine is 100 percent consistent on doing this and it has been from the time it was new. It is normal for the 3V engines and doesn't indicate a problem.
There are a number of threads about this on various Mustang forums.
However, it shouldn't burn blue any other time.
Owner1
Don't worry about it unless it gets bad. My wife's 01 cobra has done it since we bought at 5k miles.
By the way, I am a new 08 owner also. Picked up my vista blue this past week and love it!
There are many threads that talk about a bit of blowby on these 3V engines. This weekend I installed a Whipple HO and when I took off my stock intake and went to set it down, about 2 to 3 teaspoons of oil dripped out of it. This is blowby oil that is vented from the valve covers and is reintroduced into the intake. If some of this oil collected and then drained down onto the intake valve before startup, I'm sure you'd see a bit of blue on startup. I've ordered an air/oil separator to keep blowby oil from potentially fowling my intercooler. Monitor your oil consumption - if it's not excessive, I wouldn't worry about it too much.
Dude, don't take this the wrong way, because I am just trying to help you out. That word is spelled "appears".
I have problems with some words too, like wierd and neccessary ( <----- still don't know if I spelled them right )
Thank you for your feedback it is very helpful,i will continue to watch the oil level,know at 1200 mi.it appears to be down a few onces. PSYKOSTEVO must be a teacher i will try to use spell check in the future.
I'm considering the Whipple HO as well. Is the air/oil separator something that they recommend and if so, do they sell it as an option on their kit??
