A couple of weeks ago I posted about a spark plug where the center electrode broke and disappeared into #8 cylinder. We looked, could not find it, and eventually decided to remove the head for safety. No sign. Head back on. A couple of days later we heard that "burble" in the idle. I started pulling coil wires loose and when I got to #6, the burble disappeared. We pulled the plug, center electrode broken off but held in by the side electrode. But not firing very well. Looked inside cylinder thru plug hole, nothing loose in there (we were pretty sure since we had just removed the head. Replaced the plug. A day later, same problem, same plug hole. Now we are concerned. We don't see anything so we try a different plug this time (we had Bosch platinums in, replaced this one with a Motorcraft.) 5 minutes of idling and we heard the "burble" again. Went right to #6 and pulled the coil wire, motor slows down but burble is still there. Continue trying coil wires and find #4 is missing. Pull the plug and the same story, center electrode broken off and shaking inside the plug, held in by the side electrode. Replaced all plugs with Motorcraft this time around, drove for 2 days, took it to the strip, drove it some more. So far, nothing.
Anybody had issues like this with Bosch??? Never seen anything like it previously. The plug tips are not close enough to the piston to be an issue for indexing according to my depth-gauge measurements (and the plug is shrouded anyway and it would take a ton of force to first crush the shroud before the plug could contact anything...)
Friend's comment was "Germans couldn't get it right in world war I, failed again in world war II, and still can't get it right today with spark plugs."
