No its not resolved
I`m at 12 degrees base and 33 total. Running one heavy spring and 1 light one )putting the light one on helped alot). But it still kinda hesitates when I`m riding around. I`m not entirely convinced mine is tuned right yet, its only got 6 or 7 hours on it.
If I could do it over I`d go vacuum advance, even if I had to run a can to do it.
Although.....like you said about 3000 rpm`s ya better hold on to something cause all heck breaks lose. Mine is kinda scary, its like the powerband on a 2 stroke motor cycle, it just dogs to a point and then BOOM it goes.
Mess around with your base first, 15 sounds kinda high, should be 12 to 14 I think. Then mess with the springs, and its liek it came from factor, its got the 2 heaviest, change one to the lightest and drive it, see if it helps..
Oh, 1 more thing, since I put this post up I did a gear change to 355 positrack, and it made it even more crazy to drive.
