I want turbo
lvmustanggt
721
Las Vegas
Yup, turbos absolutely kick ass. However, that kit looks poorly thought out and cobbled together. They are using the stock manifolds, which means the exhaust will turn around and go to the front of the car. Then, no provisions for connecting it to the rest of your exhaust system. And a single 3" downpipe? That's what I have on my 4cyl. It'd be way undersized on a V8. I also think the turbo location is frightening. It is near the coolant resevior and a bunch of other plastic parts that don't like heat. And yes, there will be a LOT of heat right there. I've seen the turbo and exhaust manifold glowing red hot on my 2.3 many times.
:scratch: your kidding about the cams comment right?
With that cam the lift is pretty stoute so tuning becomes an issue with forced induction because the valves are left open longer and the longer duration. That is why it is recommended to go with a blower cam or something with less lift. Not saying it can't be done but it will take a good tuner to get it right
I am in vegas so it's desert. Why cause is hot ?
Turbos hate the heat...they become heat soaked and lose power.
Actually, turbos don't hate the heat. Get a proper intercooler and you can still run near ambient temperatures out of the intercooler. Roots blowers on the other hand have a heat problem. They get heat soaked because of heat rising from the engine and there isn't much room for sufficient intercoolers.
As for cam grinds and turbos... Lift has nothing to do with it. The term you are looking for is overlap. Overlap describes the duration in which both the intake and exhaust valves are open. You don't want a cam with a whole lot of overlap on a turbo engine. A grind that pulls enough vacume to run the brakes and otherwise doesn't cause drivablity problems will be just fine with a turbo or blower. I'm sure he doesn't have a grind that is really THAT wild.
There is a difference between what makes a good NA or turbo cam. In general, turbo cams will like a bit more intake duration than exhaust, while the opposite is true for NA cams.
I know it's the internet... but let's try not to spread too much mis-information.
