A bit of background: I've got a bit of an overheating issue on my GT. I haven't put any serious effort into it yet because the fan keeps the heat manageable. The engine heats up faster then it should, and will retain the heat even on the FREEWAY. But not all the time - sometimes the temp stays down at the thermostat, sometimes not. It doesn't bounce up and down, which would indicate a bad thermostat. The engine just stays warm until I turn the engine off. Next time I drive the GT, it might run cool ,maybe not. I have a mechanical temperature sensor & gauge I'll install when I'm ready to work on it, but I pick at the problem now & then.
I noticed a coolant hose that was kinda kinked. Drained the coolant, cut a bit of hose off the ends and no more kink. Since then, the engine temps have been a bit strange. I gave it a couple of days to work all the air out of the system, and the engine does run a bit cooler, it doesn't heat up as fast and the fan doesn't kick on quite as often. But here comes the weird issue:
Temp gauge is at halfway or a bit over. From a stop, if I floor it up to about 35-40, the temp gauge will quickly DROP to somewhere around the "O". This is somewhat repeatable, depending on how long I'm at WOT. The temp stays down for about a minute, then slowly climbs back up.
Anyone seen anything like this? I have a WAG (wild-@$$ guess), but I'm gonna wait until I hear your ideas.
Anyway. The radiator cover seemed to do make the issue consistent - now the engine is ALWAYS hot. I can understand the engine running warmer than usual because of the heat, but at 65+mph it should NOT be running over half way. I did pull over once to verify the fan was turning on - it was.
