What does road race trim weigh ?
When I said Road Race Trim, I meant the suspension will be setup for Road Racing, which is definitely not perfect for Drag Racing.
I took about 250# out of the chassis, but I put 180# of roll cage back in.
Bigger Transmission
Reinforced 8.8 rear
So in fact, all the weight I shed, I gained back so it's a wash.
The formula (which will be close but not exact) to calculate Hp from MPH and Weight is HP=((mph/234)^3) x weight)
Have you looked at the flow chart on those heads??
Maybe I looked at the wrong ones ?, but they are not huge.
Going from memory, those heads appeared respectable "on paper".
The Kaase cylinder heads I'm thinking of use 2.190" intake valves, 1.60" exhaust, canted (not twisted), and had sizeable intake runner volumes. I have never had one in my hands, and knowing what I know now... I would want to know what the average and minimum cross sections are also.
I'm not aware these heads are even offered to the public... this is the first, and thus my questioning.
For what it's worth, my cylinder heads flow 304cfm @ .600" with 2" bellmouth and 28" of water. My intake lift is .623" with 1.6 ratio rockers.
I hate to bench race flow benches, and flow numbers don't emulate how the engine breathes anyhow.
And how do we get another 200 hp. using a R block.?
I think I'm doing the wrong things or somebody knows somthing I don't...
Everything must be matched as a set. A combination if you will.
I've taken everything I knew from Chevys and ProStreet drag bikes and applied it to small block Fords and a lot of information and help from Jay Allen and a few others over on my "home" Board.
I have a lot of time and money invested in my topend, but that's where the acceleration and power comes from.
