MAF Meter electronics replacement....
It's really not that complicated. If the MAF meter is the only thing that's changed, the engine is still moving the same mass of air at the same rpm, load, and throttle position.
If this MAF meter setup is putting out the same voltage signals as the original one was, then the proportion of metered vs unmetered air through the housing is the same, and thus there will be no difference to the A/F ratio. You don't need the expensive gear you mentioned in order to check, all you need is an inexpensive multimeter.
That being said;
93LX it would be prudent of you to take some comparison readings between your two MAF meter setups. Test between pins C and D, and read what your voltage is at idle, 20, 40, and 60 mph. I would also test to see what your max voltage is at WOT. Do this for both setups. The higher the voltage, the richer you're running. Max possible voltage should be ~ 5 volts.
Comparing the results will let you know if you're going richer, leaner, or staying the same with your new configuration. :nice:
I'll try that after I fix the leaky power steering on my rack.
LMAO @ you for using ebay as a tech source
Sadly, I don't have the patience to run through the full explanation of how the sensor interacts with the housing.
If no one else wants to explain here, then you guys will have to do a search.
The ecu can only compensate +/- 12.5% on the Fox cars.
If your hoky MAF setup puts you outside that range, then the AFR stays there.
If your hoky MAF setup falls with in that range, then you have gained NOTHING as the ecu will push the AFR back to stoich anyway.
No gain with mismatching MAF housings & sensors... only risk...
The 94/95 MAF swap is a KNOWN alternative, and the results have been well documented by more than some 'seat-o-pants' meter lol
jason
I wasnt using it as a tech resource as you referred to in your reply. Please dont disrespect me that way. It was a pic of the MAF from the vehicle I got it from that all.
Now why is it that the only 70mm MAF you can "mod" is the 94-95 sn95. Isnt there a interchange list floating around on this site? Why are those ford cars acceptable for this "mod" but the one I got not? Gee I thought finding one that fits the stock air plumbing where you dont have to cut or adapt anything would be a good find however I get flack for even trying.
I provided all the part numbers from the stock sensor but no one has mentioned if this is close to the stock sensor fo the smaller meter or now. I would think Ford is a bit of a penny pincher when it comes to making one off parts maybe this is the same electronically with just a different connector.
I will do the measurments mentioned above and post them this weekend. If they are not over the limit then would it be said I found something soneone didnt? I m begining to feel like this is becoming a site where only proven mod are acceptable and that experimenting isnt.
Off my soap box now.
:flag:
If he is using his stock mass air meter then as long as it is in the air stream then the computer will compensate for the increased air flow I have to disagree with people saying its a bad idea, It shouldnt matter what housing the meter is in as long as the meter is in an area it can measure the air flow so i give it :nice:
It makes a huge difference which housing the meter is in. The small tube that the element is actually mounted inside of is sized to the housing and the element/meter. When you start increasing or decreasing the overall size of the meter housing it self or the size of the "sample" tube then you are throwing the air speed off as it travels through the sample tube. For an explanation of why this happens please do a web search for Bernoulli's Principal.
All of this is also how the aftermarket air meters with interchangable sample tubes work. The sample tubes have larger and smaller interior dimensions and shapes to get the air to move at a certain speed across the element to compensate for larger and smaller fuel injectors.
Note: I may not have gotten the terminology of everything correct here but this is the basic reason you should not switch sensors between housings.
:flag:
Experiment all you want with your own car. By making this post, you are suggesting others try this on their car.
not a good idea...
We only recommend the 94/95 upgrade because it is KNOWN to work. We know that it works, and we can explain/document WHY it works.
You took a random set of parts, threw them on the car, and made final determination based on your 'seat-o-pants' meter.
Now for the ebay add...
That add does NOT state what vehicle the MAS/housing was pulled from.
The seller only states that it's a good upgrade for Mustang, SHO, etc. (btw, the more applications he lists here, the better his odds of selling the meter... he is trying to SELL, and doesn't care if it is right or wrong for your car)
What sensor is in that housing?
What sensor is in your housing?
Good Job, you found a 70mm housing that is a direct swap for the stocker (this is the same as the 93 Cobra housing btw).
The part where you screwed up was by using some random sensor.
The best thing you can do with that housing is to use an F2VF sensor. The output of this setup is KNOWN... the MAF Transfer for that setup is documented.
Anything other than that is gambling...
Too many people are taking the ebay mentality to swapping MAF meters.
I can't tell you how many threads I have seen where guys have purchased the wrong meter based on some ebay lies and ended up with the car running like pooh.
best of luck to you,
jason
All true.
What you're ignoring is the possibility that this housing has the same ratio of sampled air to non sampled air as the original housing.
Jason,
I see where you're coming from, and you've made and re-made your point.
But look, he's already got the gear right?
To everybody,
The only possible edification to this thread, is if he would check the output of the new MAF setup, and compare it with the stock arrangement.
There's no purpose in busting this guy's balls at this point.
Jason,
To everybody,
You are right...
No one is listening, so I'm done.
I just don't have the patience for it anymore :shrug:
To the OP, it sounds like a worthwhile experiment. Keep an eye on the condition of the spark plugs to try and make sure the engine doesn't run lean. If you get the opportunity to dyno the car or get some A/F readings, keep us posted! I would worry that it might run lean considering the sensor is designed for a smaller housing, but you could compensate for whatever the computer can't by adjusting the fuel pressure with an adjustable fuel pressure regulator. I imagine you aren't too far off, however, because like said above, these motors can add 12.5% injector pulse width, and they are actually designed from the factory to run slightly rich at WOT.
Or, he could be so far out of whack that the computer is simply substituting default values in place of the MAF signal. The same thing as unplugging the MAF.
Like people here are trying to say, just because the car is running doesn't mean the new MAF is working correctly.
Others here are trying to say, just because it's a funky MAF arrangement doesn't mean it isn't working correctly, however unlikely.
So we have a probability wave, and both groups are right and both groups are wrong until someone actually goes in and tests it.
The tests I proposed aren't the best, but they'll give a good enough indication to know just how far off, or just how "on" the new config is. :nice:
I have had the MAS go bad before and trust me it doesnt run worht a crap. It seems to be running better but after i get my new rack installed I'll preform a idle test and see where the MAF is voltage wise and Ill run KOEO anf KOER tests.
I totally agree, but I'm trying to say that the idea shouldn't be disregarded completely immediately; it just needs some more refinement and data collection before people start shooting it down.
