Help me make my parts list!!!!
Alright, I had originally planned on buying the Trickflow trach heat package, but after doing alot of research and saving money I have heard nothing but bad things about this package.
So far I plan on going with these parts but I need some guidance for best gains.
COMP cams supercharger cam
AFR 185cc??? heads
Trickflow R-series or maybe just track heat intake
75mm TB
90mm MAF
??# injectors
1.6RR's
ARP performance headbolts
Lots of gaskets
255lph fuel pump
What else am I missing?
Camshaft Innovations or CamMotion (look for 114 lsa)
AFR 185s (wont work on stock pistons)
Trickflow R-series or maybe just track heat intake (I would Do the Holley Sys)
75mm TB (70mm is plenty for a boosted engine)
90mm MAF
??# injectors (42s)
1.6RR's
ARP performance headbolts (do studs)
Lots of gaskets
255lph fuel pump
What are you tuning with? Also what pulley combo on the Vortech and does it have a powerpipe?
Have you done a leakdown on the motor also?
As far as I know, the TFS heads are the only ones you can get away with running a 2.02 intake valve on a stock shortblock because of the canted valves. It was one of the deciding factors when I chose to buy them, myself.
