Cobra123089 Member Sep 30, 2006 94 0 7 Broomfield CO/ Laramie WY Sep 12, 2008 #1 Sep 12, 2008 #1 Ok im looking to get Patriot Stage 2 heads withing the next couple of weeks, my question is will the valve springs that come on the head be good for comp cams 270's? I can not find any info on them and I'd rather be safe then sorry. Thanks
Cobra123089 Member Sep 30, 2006 94 0 7 Broomfield CO/ Laramie WY Sep 12, 2008 #2 Sep 12, 2008 #2 Found this. This single spring configuration has 115 lbs on the seat and 285 lbs open. Do you think this is good enought for 270 comp cams?
CobraRed_96_GT Active Member May 20, 2006 1,421 4 39 UCSD/La Jolla Sep 12, 2008 #3 Sep 12, 2008 #3 Cobra123089 said: Found this. This single spring configuration has 115 lbs on the seat and 285 lbs open. Do you think this is good enought for 270 comp cams? Click to expand... Ha, yeah. That's plenty of pressure.
98COBRA281 10 Year Member Nov 24, 2007 1,348 30 59 Port St. Lucie, Florida Sep 12, 2008 #4 Sep 12, 2008 #4 Cobra123089 said: Found this. This single spring configuration has 115 lbs on the seat and 285 lbs open. Do you think this is good enought for 270 comp cams? Click to expand... yeah thats a good spring, my comp springs have 93lbs seat pressure, and 198lbs open pressure.....
CobraRed_96_GT Active Member May 20, 2006 1,421 4 39 UCSD/La Jolla Sep 12, 2008 #5 Sep 12, 2008 #5 98COBRA281 said: yeah thats a good spring, my comp springs have 93lbs seat pressure, and 198lbs open pressure..... Click to expand... Ditto
