Exactly what I was getting at Joe
Individuals can do this as favors or "business"
Few large companies will jump into the custom mail order tune business, as the risk would be rather large.
There's a couple of weasels out there who will take your $$$, and send you a chip... they don't care (or even know) how your car will perform with that chip...
My advice is to take the car to a dyno shop, or learn to do tune via the J3 yourself.
We agree.
I honestly have
very mixed feelings about custom mail order chips.
Many people don't have a dyno shop or tuner near them that is really experienced with Stangs. Then, there's the problem of getting there, getting an appointment, and so on. So, for those people a simple custom chip is a better solution than going with just a scaled MAF (adj FP for SD).
There are a number of cases where going to 24's makes sense and are needed.
*I* suggest that people get the '93 Cobra setup (EEC and MAF - and keep the stock air box). By far, it's the safest way.
But, some people don't want that. And, it's "somewhat safe" going with a high-end PMAS MAF, with the stock air box, and getting a custom chip with the exact MAF map and injectors map put into the chip.
If someone has a cam with a lot of overlap, the simple custom chip can even "kinda" help at idle by setting the idle speed higher.
All of the above is a
lot better than what many people do - go with a just a "scaled MAF", and/or C&L, and/or a MAF with a cone filter on the end. Any of those is asking for trouble. Yet,
many people do exactly those things and they "are mostly happy".
So, I suggest the 93 Cobra EEC and MAF and 24's. That's a great
very cheap option and will get a person "most of the available gain". Or, high-end PMAS, stock air box, and custom chip with MAF map and injectors. That gets a person very close to their max gain.
But, to truly tune a modded engine, there are many variables, and a Mustang Dyno (load bearing dyno run) with data logging are really needed to get that last ~5-10%. I say Mustang Dyno instead of a drive because it's not
legal to drive as fast as needed to tune at WOT. And, again, many people don't have qtr mile tracks near them, and/or it may be very inconvenient to get to the track.
Also, with mail-order custom chips, the person ordering the chip often isn't very experienced and/or doesn't have a good ability to diagnose a problem. Also, you get the people that think that a custom chip will make their rough-idling 5.0 all of a sudden idle like a Camry!
Between the scam artists and the people doing the mods that don't even know how to use a simple scan tool, there are a
ton of potential problems. I hate seeing people get screwed or scammed. With custom chips, even well meaning and good companies and people get stuck with many headaches. And, there are also mail-order chip people out there that _say_ they'll enter in a custom MAF map, but don't. They also _say_ they do a lot of other things in their chip setup, but they do not.
Something else for people to consider. An engineer makes ~$80K-$120+K/year. That's at least ~$45/hr. In New England, the going rate for a Software or Hardware Engineer is a between $50/hr for a low-level junior engineer, up to $100+/hr for some Principal Engineers.
So, IMHO, doing custom mail-order chips doesn't make much sense for many engineers. For now, the demand for Engineers is still pretty good. That's very different than in 2001-2002 when having an engineering degree was like having the plague when talking to recruiters and HR people.
So, before someone gets a mail-order chip, if it's one of those cheaper mail-order chips, they should ask themselves who do you think you're getting the chip from? If a person wants just the
basic MAF/injector/idle-speed changes, then they "should" be okay. IMHO, a typical high school student could learn how to do those changes for a custom chip in under two hours. (Learning just the "read the change request specs and then do-this" part of doing a custom chip. Not what it really means.) Then, it would take the mail-order chip seller ~15->30mins to do each new chip (emails, burn, ship, etc). But, if a person is expecting (or promised) more from a custom mail-order chip, then I would say someone isn't being realistic.
For reference:
In the year 2016: The 30 fastest-growing occupations - Boston.com
So, as I said, I have
very mixed feelings about mail-order custom chips. I do think they have a place. But, many potential problems.
